All
On my165 there are what look to be two hydraulic fittings that are connected by a small loop of tubing. On my quadrant I have a option to select constant pumping and adjust the pressure from high to low. Can theses taps be used to drive the loader?
If so, then I would think that I can eliminate the selector valves that are under the seat and when I want to use the loader I can just select constant pumping on the quadrant. When I want the 3PT I just use the quadrant as designed.
It seems the only change would be that when I put the QD hoses onto the taps there would be no loop when the loader is not on the tractor.
Is that a problem?
Am I thinking about that correctly?
Is that a problem?
