TractorLinks.com
Show Parts for Model:
Re: Masseynut Help! 65 pump
Masseynut(Australia)
01-24-2013 20:32:17
Hi Richard, Not sure what you mean by "multi-power gear" on the shaft? Only the main hydraulic piston pump can be removed thru the top aperature. If it still has the auxillary pump piggy-backing it, it will have to be removed. I can't remember your application, but early Masseys had a single plate mounted to the main pump. It is possible to remove the auxillary pump from the plate, lift it out, then remove the plate and remove the main pump. Later tractors had a "plated drive" bolted to the front of the main pump. You will need to split the tractor to remove this assembly and main pump. If you only have the main pump to deal with, try removing the PTO shifter side cover, and sliding the engagement gear rearwards fully. There should be enough clearance between the pump and the pinion shaft to clear it. Let us know your progress, Evan.
