| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: ? on O-rings in 44 block
[Return to Forum]
| Author |
[Modern View]
| Scott(IN)
01-24-2013 15:30:19
199.16.223.2
I in the process of overhauling a 277 engine. There are some pits where the o-rings seat in the block for the sleeves. Maybe things will work just fine, but I only what to do this once. Just wondering what others have done. Looks like I could coat the o-rings with RTV gasket maker, but didn't know if that is proper or not. |
[Reply] [No Email] | |
| Mike in Mn.
01-24-2013 20:46:26
74.37.49.109
Re: ? on O-rings in 44 block in reply to Scott(IN), 01-24-2013 15:30:19
| On those blocks and all old tractor blocks I clean the bores with a glaze breaker cylinder hone, It will ruin the stones but you will get all four holes done with one set. Usually where the bottom rings set is good, only where the top ones set are pitted from the coolant. I have been installing sleeves with Ultra-Copper as a lube and sealer. Install the rings on the sleeves dry, run a pick under and around them to make sure they do not have a twist, coat the bores with Ultra-copper and coat the sleeve between the o-rings so the top ring will have sealer(the bottom ring going in will wipe the bore). Don't use blue, red, or black, only Ultra-Copper! I have installed sleeves in some pretty nasty looking bores and have never had one leak, have some out there ten years, I use this method on all installs now. This is what works for me, Good Luck on your project! Be sure and dry fit first and index and mark the rod slots. |
| matt p
01-24-2013 20:20:49
69.31.197.148
| I've heard of people using plumbers gas fitting pipe dope. its rated for gasoline,propane,natura gas they use on rubber washers and o'rings. |
| rustred
01-24-2013 17:42:47
69.58.16.5
| if it was mine i would use jb weld on the pits , let it dry good then sand it smooth with some emery cloth. |
| marloweg
01-24-2013 16:17:42
184.157.219.229
| i have had some over the years that were pitted fairly bad i might have been just lucky but i just cleaned the block [real good]and used a good lube on the O rings and slipped the sleeve in and i never had any leaks might have been lucky but it worked i also put a can of bars leak in the radiator also |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
