| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Re: MF 360 Engine Noise
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| DavidP, South Wales
01-20-2013 08:24:07
78.148.188.55
Hi Brad, Very likely causes are a failed small end bush or a big-end bearing. Turn the engine in the direction of rotation until number three piston starts to go down. When it is an inch or so from the top stop. Try and push the piston down by hand. I suspect that you will be able to push it up to 1/8" before it stops. If this is the case you will need to remove the sump (oil pan) to gain access to either and to be able to remove the piston if the BE journal is damaged. Check the condition of the crank journal thoroughly. DavidP, South Wales. |
| Brad (Lonoke)
01-20-2013 09:56:01
166.137.145.102
Re: MF 360 Engine Noise in reply to DavidP, South Wales, 01-20-2013 08:24:07
|  Will try it today and post results. Can the sump be removed without taking front end of and splitting tractor? |
| Brad (Lonoke)
01-20-2013 14:14:19
99.195.124.244
Re: MF 360 Engine Noise in reply to Brad (Lonoke), 01-20-2013 09:56:01
| DavidP- You were spot on. I turned the engine until piston was traveling down. With the piston one inch below the top of block I manually pushed down on the piston and discovered about 1/8 drop. So, I'm on to removing the sump. My plan is to look for a bearing or wrist pin problem. Will post an update. |
| Brad (Lonoke)
01-20-2013 15:01:10
99.195.124.244
Re: MF 360 Engine Noise in reply to Brad (Lonoke), 01-20-2013 14:14:19
| Here's what she sounded like before I began the tear down.
http://youtu.be/aK6heMbEiMs |
| matt p
01-20-2013 10:49:52
69.31.197.148
| looks the same as my 202 when I got the pan off I had broken the crankshaft, hopefully YOU don't have that happen could be wrist pin ,rod bearings |
| Brad (Lonoke)
01-20-2013 13:33:01
99.195.124.244
Re: MF 360 Engine Noise in reply to matt p, 01-20-2013 10:49:52
| Thanks for the post, looking forward to getting inside there and taking a good look. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
