TractorLinks.com
Show Parts for Model:
Re: carb linkage z134
Inno
01-15-2013 14:16:07
I don't think the throttle has a spring on it at the carburetor. The choke does, but not the throttle.
If you push the throttle lever back by hand will it go any lower? Is the adjusting screw in place on the carb for idle speed? What about with the governor linkage removed, will it go back to idle then?
Yeah, you can't set the timing at all if you're not at idle, it starts advancing pretty early, at least my 35 does. Got it timed the other night, it sounds really nice!! Still got a carb issue, not getting enough fuel when you snap the throttle open, carb was soaked in carb cleaner for 2-3 days and all new parts were put in. Anyway.....this is Matt's post, back to your idle problem.
This post was edited by Inno at 14:20:09 01/15/13.
matt p
01-15-2013 15:59:01
 Re: carb linkage z134 in reply to Inno, 01-15-2013 14:16:07
thanks guys I just picked up the carb kit.I know why my hand throttle was not working,small drip falling off from oil pressure gauge right on to my new cork washer !!!! Inno I can lower the idle by hand but cannot get it idle below 600 stalls out. I am going off the tractor meter/tachcometer so I'm not sure how accurite it is ?? I'm going to pull carb off tonight for good soak.
