| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: MF 20 Ind wiring
[Return to Forum]
| Author |
[Modern View]
| Samuels68
01-13-2013 12:35:07
173.215.11.129
Here I am again guys, asking for advice cause I am stumped....
My Industrial 20 (3cyl Perkins Gas) seems to have a wiring problem that I can't manage to track down. I have traced every wire (except for the light circuit which is unhooked) and replaced damaged wiring so that everything is complete and matches the diagram.
I replaced the ignition switch because the old one pretty much fell apart when I touched it, and replaced the voltage regulator that was pretty well baked. It appears as if the battery moved in the tray (hold down clamp long gone when I got it) and pinched a wire coming from the regulator, causing a short, and heating which cooked alll the wiring within 2 inches of the regulator, all of which I replaced.
I have a good battery installed and am getting 13+ volts from positive to negative and positive to engine block. I have 13+ volts to the starter wire. However, I have no voltage to the ignition switch, and obviously, none coming out of the ignition to fire the solenoid.
I have not resorted to jumping the solenoid straight from the starter wire for fear of damaging something further, but I am about to that point.
Obviously, I am missing something, but can't seem to put my finger on it.
Any help or advice would be greatly appreciated.
Thanks,
Jess |
| Samuels68
01-13-2013 20:16:51
173.215.11.129
Re: MF 20 Ind wiring in reply to Samuels68, 01-13-2013 12:35:07
| I'm quickly beginning to hate them myself!! I think I will remove the wire from the voltage regulator and add one straight from the starter battery terminal. Your suggestion got me thinking...Why does the voltage regulator need to be in the start circuit anyway? If the engine isn't turning, the alternator has no output, thus the regulator has nothing to regulate, right?? Just a thought, but I'm gonna try it. Whats the worst that could happen, right?
Thanks
Jess |
| Samuels68
01-13-2013 14:28:10
173.215.11.129
| Phil, that seems like it would work to me, but do i disconnect the wire that is currently on the "Bat" terminal (It comes from the voltage regulator) or do I leave it there and add the new wire to it? |
| Phil Tibbetts
01-13-2013 18:55:03
208.93.14.38
Re: MF 20 Ind wiring in reply to Samuels68, 01-13-2013 14:28:10
| I'm not sure just how your regulator is wired so I can't help you on that. I use the single wire alternators on all my equipment. I hate external regulators. |
| Phil Tibbetts
01-13-2013 12:56:15
208.93.14.38
| I think you need to run a wire from the starter battery connection to the switch terminal Bat. then a wire from switch starter terminal to solenoid. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
