swappin' manifolds
The manifolds will fit on either engine.The propane manifold works very well on the gas engine.It keeps the air feul mixture cooler which makes the engine work way better.Putting the gas manifold on the propane engine may cut down the engine performance by heating up the air feul mixture to much.The engine will still run useing the gas manifold I am just not sure how it will perform.I put a propane manifold on the first 55-gas I had and it made a remarkable differance in how the engine performed.I hope this helps you with your project.
