| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: MF 231 injection pump problem
[Return to Forum]
| Author |
[Modern View]
| Roy G
01-10-2013 18:18:00
75.248.245.181
Working on a 231 for a friend. He bought tractor running but had a lot of blowby and hard to start. Took it apart, had broke rings and a blown head gasket probably from ether. Took pump off for engine rebuild and now that I have put back on, can get no fuel to injectors. Cleaned out tank and screen on cutoff valve,blew out all lines and a new fuel lift pump. Injector pump is full of fuel and I know I have it bled of all air but all I get is a dribble of fuel at injector lines. I also know I timed pump correctly when I put timing gears back on. Anybody got any ideas? I'm 60 years old and I've been working on these old tractors for years. I'm thinking something is wrong in the injection pump but was running when drove into my shop. Any comments appreciated. Thanks.Roy G |
| dgerth
01-12-2013 08:58:44
64.139.109.142
Re: MF 231 injection pump problem in reply to Roy G, 01-10-2013 18:18:00
| Just an idea, perhaps plugged return line. Had this happen before. dg |
| Roy G
01-11-2013 17:03:41
75.255.251.74
| Guys, thanks for all your answers. The pump has been sitting on a shelf for about a year now. I suspect as dieseltech said something has probably stuck in pump. With bleeder plug out of side of pump body, when you turn over engine shoots out plenty of fuel. I had thought of pulling it to try and start. When ground dries up a little here I will round me up a helper and give that a try. Thanks for all replies |
| Dieseltech
01-12-2013 09:01:17
199.16.223.2
Re: MF 231 injection pump problem in reply to Roy G, 01-11-2013 17:03:41
| If pump has not been run that long I am sure plungers and metering valve are stuck, and pull starting most likely won't work. Have repaired too many pumps in this condition, best to do a complete teardown and reseal. Just mailed back a 135 pump that had the same trouble. Good luck! |
| Fergie Bach
01-11-2013 02:24:39
78.150.246.199
| Once in a while the only way to generate enough "force" is to give the tractor a good hard pull up and down a road. Perhaps with one injector pipe slackened. You seem to have covered everything really. Let us know what happens. |
| mike tn
01-10-2013 20:08:43
75.138.242.232
| Roy G - i'm no where near the mechanic you are but try taking off the output line on that new fuel lft pump and make sure it's pumping out enough fuel. I have had problems with new ones. |
| Dieseltech
01-10-2013 18:51:21
199.16.223.2
| If pump has not been used recently metering valve and/or plungers may be stuck from setting while engine was being repaired. Just mailed one back that had the same trouble. How long has it been since the engine ran last? |
| DoubleR
01-10-2013 18:43:29
198.105.230.174
| Did you take the plastic pet-cock on the bottom of the fuel tank apart and clean the crud out of it. I have to on my 231 every few years. It will start acting like its running out of fuel when working it hard. It will restrict the amount of fuel that is able to flow through. Just a suggestion. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
