GEB
New User
I have a couple of MF 165s that I am going to part out. Both have Multi Power transmissions. Basically I have everything available except the sheet metal. One tractor is diesel and the other one is gas (no carb). Located in North Carolina app 50 miles southeast of Raleigh. Let me know what you need.
(quoted from post at 19:14:12 11/24/12) I have a couple of MF 165s that I am going to part out. Both have Multi Power transmissions. Basically I have everything available except the sheet metal. One tractor is diesel and the other one is gas (no carb). Located in North Carolina app 50 miles southeast of Raleigh. Let me know what you need.
Hi, are you still parting out the 165 diesel?
I'd be interested in:
-Dash panel
-Injector pump
-Starter
-Lift arms
-Really need sheetmetal, but I see you don't have.
-Gas tank support where the voltage reg bolts to. Can give massey p/n for reference.
-clutch pedal, and the linkage part that has the two holes.
-warning flashers
-work light
This is just a laundry list of parts i need for my 165 i'm redoing.
If you can help let me know!
