TractorLinks.com
Show Parts for Model:
Re: MF 1085 Splitting
DavidP, South Wales
01-06-2013 10:59:25
Hello Grant,
In all probability you have not disconnected the hydraulic flexible pump which runs from the front port of the auxillary pump forwards.
It is attached to the aux pump by a banjo bolt and may require a spanner to be bent to fit it.
Do not put any more pressure on trying to seperate the two halves. The pipe has a semi circular rear end. Make sure that this has not been flattened.
Have you removed the hydraulic cover? If not, you will need to to gain access to the pipe.
DavidP, South Wales
CBBC
01-06-2013 14:41:16
 Re: MF 1085 Splitting in reply to DavidP, South Wales, 01-06-2013 10:59:25
Thsnks David,
I removed the banjo fitting - then with a lot of wiggling we rolled it back.
Once appart we could see the brake band was broken. We then took the side cover and top cover off and removed the pieces from fron to back until we got the clutch pack with the brake out. A lot of work for a small part. I will go order it tomorrow.
Thanks, Grant
