| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Re: MF 360 Starter Wires
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Masseynut(Australia)
01-05-2013 20:54:31
101.162.154.2
Your lift pump may or may not have a dome shaped cover on the top half of the pump. Is this where the "rattling" sound is coming from? A single screw will remove this cover. Are the valve assemblies on the underside of the top half still in place? Check that they are still firm in their seats and haven't come loose in the body, also check that there isn't any of that debris you found earlier, jammed under the valves or in the the hair springs. Let us know your progress, Evan. |
| Brad in Lonoke
01-07-2013 17:45:38
174.125.165.142
Re: MF 360 Starter Wires in reply to Masseynut(Australia), 01-05-2013 20:54:31
| | Masseynut- Success!!! You're the man! Has a hard knock to it, but may need to be run a bit. I appreciate all the good info. Cheers! http://www.youtube.com/watch?v=zJFtIQ_trQA |
01-08-2013 02:55:04
101.162.154.2
Re: MF 360 Starter Wires in reply to Brad in Lonoke, 01-07-2013 17:45:38
| Brad, I'd get an external oil pressure test gauge onto your engine before you run it any more. Unscrew the oil pressure sender unit from the engine block and fit the test gauge to the block. That "hard knock" could just be a faulty injector on one cylinder, but just to make sure the bottom end of the engine is not the source of the "knock", check that oil pressure. Chances could be that the oil pressure light on the dash is not working. It should light up when the key is turned to the "on" position, along with the alternator and transmission oil pressure light. let us know what the outcome is from here, Evan. |
| Brad in Lonoke
01-08-2013 21:28:54
99.195.237.167
Re: MF 360 Starter Wires in reply to Masseynut(Australia), 01-08-2013 02:55:04
| | Checked oil pressure with external guage, reads around 50 psi. Loosened each fuel line at injectors, listened for degraded performance, tightened, all injectors seemed to be operating correctly. http://www.youtube.com/watch?v=aK6heMbEiMs http://www.youtube.com/watch?v=SYLc71q9yhw |
01-09-2013 03:28:39
101.162.154.2
Re: MF 360 Starter Wires in reply to Brad in Lonoke, 01-08-2013 21:28:54
| The fact that the oil pressure is up there very good news. This eliminates the bottom end as the source of the knock. When you rev the engine, is it blowing any smoke from the exhaust? What colour is the smoke? Does the knock tend to even out at higher revs?Short of carrying out a compression test on each cylinder, I'd remove the muffler and air intake hose at the manifold, and crank the engine with the stopper out. If you hear any sign of air leakage, (slurping) to a certain degree when turning the engine over, I'd suspect either a badly seating exhaust or inlet valve, or more likely a blown head gasket. The latter is most likely. As I said, a compression test will soon confirm this. Let us know your progress, Evan. |
| Brad in Lonoke
01-10-2013 16:48:16
99.195.221.221
Re: MF 360 Starter Wires in reply to Masseynut(Australia), 01-09-2013 03:28:39
|  Smokes initially, white, knocks at low idle and upper rpms. http://www.youtube.com/watch?v=dB44xrjiWEw "...crank engine with stopper out."? This is likely the problem. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
