TractorLinks.com
Show Parts for Model:
Re: MF 360 Starter Wires
Masseynut(Australia)
01-05-2013 02:55:41
Yes, drain the tank and re-fuel. There will be a shut-off tap, either at the base of the tank, or on the lift pump. Make sure that you have unrestricted fuel flow past this tap. Next, check the strainer in the top of the lift pump itself. Remove the cover from the lift pump and remove any crud from the strainer and with-in the cavity of the pump body. The filter is the next port of call for the fuel on it's way the engine, so replace it and also check and tighten all pipe fittings here. An ingress of air, or a fuel leak can occur at a loose pipe fitting. Next, go to the injector pump, and remove the lower of the two bleed screws. The one in question is located about half way along the round part of the "body" of the fuel injection pump. It will be unscrewed with a 5/16" AF ring spanner. Remove it completely. Now, prime the lift pump by hand. You should get a solid flow of fuel from this port on the pump.
If this is not possible, try rotating the engine itself, either by hand, or with the starter motor roughly 180 degrees. Try the primer lever again, you should "feel" some resistance thru the stroke of the lever. Fuel should now flow solidly from the injector pump bleed-screw. Refit and tighten the screw. Now loosen one of the three injector lines to the cylinder head roughly two turns. Pull the hand throttle a third of the way down, and crank the engine. The engine should start to fire on the other two cylinders. Once this occurs, tighten the fitting. Job done (hopefully). Let us know your progress, Evan.
Brad in Lonoke
01-05-2013 18:29:05
 Re: MF 360 Starter Wires in reply to Masseynut(Australia), 01-05-2013 02:55:41
Drained tank found sediment and debris, will clean out thoroughly tomorrow. Removed lift pump but didn't find anything remarkable,split in half, not sure if it disassembles any further. Something rattling inside top half. Will evaluate further tomorrow. R/R fuel filter (Wix #33358 canister type), very dirty fuel in there. Will tighten all fittings, bleed, and prime as per instructions above tomorrow. Thanks for the info.
01-05-2013 20:54:31
 Re: MF 360 Starter Wires in reply to Brad in Lonoke, 01-05-2013 18:29:05
Your lift pump may or may not have a dome shaped cover on the top half of the pump. Is this where the "rattling" sound is coming from? A single screw will remove this cover.
Are the valve assemblies on the underside of the top half still in place? Check that they are still firm in their seats and haven't come loose in the body, also check that there isn't any of that debris you found earlier, jammed under the valves or in the the hair springs. Let us know your progress, Evan.
Brad in Lonoke
01-07-2013 17:45:38
 Re: MF 360 Starter Wires in reply to Masseynut(Australia), 01-05-2013 20:54:31
Masseynut- Success!!! You're the man! Has a hard knock to it, but may need to be run a bit.
I appreciate all the good info. Cheers!
http://www.youtube.com/watch?v=zJFtIQ_trQA
01-08-2013 02:55:04
 Re: MF 360 Starter Wires in reply to Brad in Lonoke, 01-07-2013 17:45:38
Brad, I'd get an external oil pressure test gauge onto your engine before you run it any more. Unscrew the oil pressure sender unit from the engine block and fit the test gauge to the block. That "hard knock" could just be a faulty injector on one cylinder, but just to make sure the bottom end of the engine is not the source of the "knock", check that oil pressure.
Chances could be that the oil pressure light on the dash is not working. It should light up when the key is turned to the "on" position, along with the alternator and transmission oil pressure light.
let us know what the outcome is from here, Evan.
Brad in Lonoke
01-08-2013 21:28:54
 Re: MF 360 Starter Wires in reply to Masseynut(Australia), 01-08-2013 02:55:04
Checked oil pressure with external guage, reads around 50 psi. Loosened each fuel line at injectors, listened for degraded performance, tightened, all injectors seemed to be operating correctly.
http://www.youtube.com/watch?v=aK6heMbEiMs
http://www.youtube.com/watch?v=SYLc71q9yhw
01-09-2013 03:28:39
 Re: MF 360 Starter Wires in reply to Brad in Lonoke, 01-08-2013 21:28:54
The fact that the oil pressure is up there very good news. This eliminates the bottom end as the source of the knock. When you rev the engine, is it blowing any smoke from the exhaust? What colour is the smoke? Does the knock tend to even out at higher revs?
Short of carrying out a compression test on each cylinder, I'd remove the muffler and air intake hose at the manifold, and crank the engine with the stopper out. If you hear any sign of air leakage, (slurping) to a certain degree when turning the engine over, I'd suspect either a badly seating exhaust or inlet valve, or more likely a blown head gasket. The latter is most likely. As I said, a compression test will soon confirm this. Let us know your progress, Evan.
Brad in Lonoke
01-10-2013 16:48:16
 Re: MF 360 Starter Wires in reply to Masseynut(Australia), 01-09-2013 03:28:39
Smokes initially, white, knocks at low idle and upper rpms.
http://www.youtube.com/watch?v=dB44xrjiWEw
"...crank engine with stopper out."?
This is likely the problem.
