Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Massey Harris 33
Rich Doney
01-03-2013 16:54:13
yes the shaft turns with the gear when spun
marloweg
01-03-2013 17:11:53
 Re: Massey Harris 33 in reply to Rich Doney, 01-03-2013 16:54:13
will if your sure the pin is not sherd then the only two things it can be broken cam shaft or gears are striped or nut holding gear to shaft backed off and gear fell off from cam. but first made real sure gear is tight on shaft of dis.you can check to see if cam is turning by looking down the hole with a light while someone turns it over.do you have a hyd. pump on this tractor if so then it could very well be the cam is broke they will brake the cam because the pump runs off the cam gear have changed a few over the years
Rich Doney
01-03-2013 18:02:08
 Re: Massey Harris 33 in reply to marloweg, 01-03-2013 17:11:53
I will make sure.We were using the hydraulic remotes when it did this.Im going to check that in the morning
marloweg
01-03-2013 18:04:20
 Re: Massey Harris 33 in reply to Rich Doney, 01-03-2013 18:02:08
sorry to say you have a broken cam shaft 100% sure
marloweg
01-03-2013 18:06:28
 Re: Massey Harris 33 in reply to marloweg, 01-03-2013 18:04:20
finding a cam is not going to be EZ !!!! what state you in ???
Rich Doney
01-03-2013 18:19:27
 Re: Massey Harris 33 in reply to marloweg, 01-03-2013 18:06:28
Greattt.... Maryland
