Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: MF 35 DIESEL
[Show Entire Topic]  [Return to Forum]
Phil H
01-03-2013 13:34:53
75.40.18.82
Thanks, the mower I was thinking about would be a mower conditioner, if that makes any difference, the only experience I have is with a Ferguson and a sickle mower, and it worked great except for the mouse nests getting caught on the gards, never used a conditioner, and it gets pretty hot with little rain so maybe just a sickle mower and side delivery rake would work the best. If a 35 won't pull a mower conditioner then it surely won't pull a baler. Maybe I need to go a little bigger.
[Reply]   [No Email]
DavidP, South Wales
01-03-2013 14:55:49
2.100.121.38
 Re: MF 35 DIESEL in reply to Phil H, 01-03-2013 13:34:53
Hi Phil,
If your weather is mainly very dry you probably would not benefit fully from using a conditioner.
In the UK and Europe the use of a conditioner will hasten the drying of hay or silage by about 24 hours.
If you go for a mower only then the 35 will be ideal. The 35 will handle a 5'6" cutterbar or sickle as you call them or alternatively a 4'6" rotary drum mower with little weight loss on the front end of the tractor.. Having the smaller cut can of course cause problems in the working width of the first machine that you put through after mowing.
Sadly mouse nests clogging the fingers are a fact of life for a cutterbar mower. That is the beauty of the drum and saucer mower...you don't get off the tractor from start to finish.
The 35 would be ideal for a small baler because you have the flywheel to give you momentum and your forward speed is limited.
If you are not likely to be in a great rush, weather threatening etc to make the hay then the 35 will make an ideal tractor. Its economical and parts are readily available.
Cheers
DavidP
[Reply]  [No Email]
Phil H
01-03-2013 18:35:41
75.40.18.82
 Re: MF 35 DIESEL in reply to DavidP, South Wales, 01-03-2013 14:55:49
Thanks David, you have given me a good deal of information, I think the MF35 is a real good all around tractor. What do you think I should look for in a used unit. I think you can look it up in craigs list, Oregon, and see a MF 35 with a new engine and it looks like someone took good care of it, they want $4500. U.S. which doesn't seem to far out of line. Thanks again.
[Reply]  [No Email]
DavidP, South Wales
01-04-2013 01:10:05
2.97.136.147
 Re: MF 35 DIESEL in reply to Phil H, 01-03-2013 18:35:41
Good morning Phil,
First of all stand back and look at it. Is the bonnet (hood) straight and in good condition? Read its history from the appearance. Look at the tyres all round espacially for any cracking in the walls. How much wear is present on the pedal grips? Are the linkage balls in the lift arms loose? Is there any excessive wear in any part of the 3-point linkage? Check the brake backplates for any sign of oil or dampness caused by a leaking seal. Are the brakes satisfactory?
How much play is in the steering? Check for wear in the front axle pivot bush and pin and steering ball joints. Check for any gap under the steering arms on the front axle. A gap of over 1/8" would suggest wear in the thrust bearings. Is there any play between the drop arms from the steering box (one against the other)?
Find out what has been done to the engine with receipts if possible. Check for good starting and no or very little blowback from the dipstick hole. There is a bolt at exactly the 12 o'clock position attaching the gearbox to the engine. Check if it is there. Many leave the bolt out because its a little awkward to fit. If the bolt is there then for me its a sign that the repairer has be conscientious enough to fit it.
Drive the tractor in all gears and apply the brakes firmly but briefly and listen for any strange noises. Check smoke emission when doing this.
I don't have the pound/dollar conversion to hand but in the UK I'd expect to pay between £2000 to 2500 for a good 35. If it all checks good and you can buy it for close to $4000 you should be onto a winner.
DavidP
[Reply]  [No Email]
Phil H
01-04-2013 03:58:00
75.40.18.82
 Re: MF 35 DIESEL in reply to DavidP, South Wales, 01-04-2013 01:10:05
Hi David, I will print out this list and use it to check out the tractor, looks like it would be a good gauge for almost any machine. Thanks you very much.//// Phil
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
