Voltage regulator
Samuels68
I believe the voltage regulator in my industrial 20 may be bad. Near as I can tell the MF part number is 1031060M91. Is there a way to test these?
Thanks in advance.
Jess
First, be sure your gen/alt and battery are in proper working
condition.
if they are good, then just replace the voltage regulator with
the best one you can buy.
I am sure someone with proper test eq could test out the
unit but I never had much luck.
Thanks guys. I figured if there was an easy way to test it I would, but a new one is only about $30 with shipping. This one did last 42 years so I guess its worth $1 a year :)
