TractorLinks.com
Show Parts for Model:
165 - adding foot control
MT in PA
12-31-2012 15:17:50
Hello all
I'm new to tractors and the YT site. It's good reading......
I purchased a1967 MF165 with a MF quick disconnect loader. I'm spending some time over the winter fixing and making some small modifications, like adding a foot control throttle.
I discovered that the existing hand throttle linkage was not in great shape and missing some springs. In the shop manual I noticed that the picture showing how to adjust the linkage has a spring (I assume a return spring) on the bottom of the linkage. Can someone tell me were the other end of the spring attaches to? I could also use a pic or drawing of how the foot throttle is integrated?
Any help would be appreciated, thanks
MT in PA
01-02-2013 19:46:13
 Re: 165 - adding foot control in reply to LarryM, 12-31-2012 15:17:50
Sam and Samuel thanks for the help. I don't think the linkage is the same on the 135 gas
Sam is yours a 165? The linkage looks close and makes mechanical sense to me but my cross linkage does not have that quadrant plate on the end. It also looks like the very bottom of your hand throttle shaft has a fitting on it. Mine does not have that but as I said, I think the PO made some changes. I'll check Sparex. That's for the tip.
samn40
01-03-2013 01:33:50
 Re: 165 - adding foot control in reply to MT in PA, 01-02-2013 19:46:13
Yes the tractor in the picture is one of the very first 165s to roll off the Banner Lane assembly line and has the 203 engine. It is a well used example that I have in dry storage to hopefully restore some day....The serial number is 61....possibly built the very first day? Sam
MT in PA
01-03-2013 16:03:58
 Re: 165 - adding foot control in reply to samn40, 01-03-2013 01:33:50
#61, nice resto project...I hope you get to do it.
Thanks again for all help. You have confirmed that my linkage is as best assembled wrong, at worse a Rube Goldberg. The question now is why and how to fix it.
I gave a quick look on Sparex but could not find the parts. I guess foot control goes on the bottom of the project list......
MT in PA
01-03-2013 15:20:37
Samuels68
01-02-2013 18:48:32
 Re: 165 - adding foot control in reply to MT in PA, 12-31-2012 15:17:50
I have a 1970 industrial 20 (basically a 135) with a perkins gas engine, and my foot throttle linkeage looks somewhat different than samn40's photos show. I could try to take some pics if like, but everything is kinda buried behind the air cleaner and hard to see. Let me know if you want some pics.
Jess
samn40
12-31-2012 17:01:14
There was a foot throttle as standard on all our 100 series, You may be able to find one on a scrapped industrial in America. Sam
MT in PA
01-01-2013 05:00:32
 Re: 165 - adding foot control in reply to samn40, 12-31-2012 17:01:14
Sam
Thanks for the reply. I have the pedal assembly and a linkage but I know where the pedal linkage is supposed to attach to the existing linkage. As my existing linkage had been repaired/modified by the previous owner I don't know what it's supposed to look like. To clarify, I need a pic or drawing of the RHS linkage.
Its a Perkins diesel if that makes a difference.
samn40
01-02-2013 11:58:24
 Re: 165 - adding foot control in reply to MT in PA, 01-01-2013 05:00:32
Sorry for taking so long to reply, but I have been down with 'flu and only made it over to the shop this afternoon to take these pics. I hope they help. Parts for these throttles are available from Sparex. Sam
MT in PA
01-01-2013 14:00:58
Correction. I don't know where the pedal linkage is supposed to attach to the existing linkage. MT
EJ70
01-01-2013 08:41:06
MT
Did you go up to Ervins? You are welcome to stop by a look at mine.
Eric
MT in PA
01-01-2013 13:49:52
 Re: 165 - adding foot control in reply to EJ70, 01-01-2013 08:41:06
Eric,
No need to go to Ervin's. Got one on-line pretty cheap.
I'll probably stop by for a look over the weekend if your home. I thought your hand control was not working?
On another note. I took off the PTO selector cover to get at that brass filter as you suggested, but no chance. The aux hydraulic lines are in the way. Unless you have another idea.....
MT
