i have a Massey Ferguson 245 Perkins diesel. it has been leaking out the top of the injector pump since i bought it and has gotten worse every year. from what i can tell it is a pretty common problem and i see it brought up in a few posts but haven't been been able to find a post specifically on replacing the seals. from what i have gathered is it in not too bad. pump doesn't need to be removed and parts are pretty cheap but there is a procedure that needs to be followed... would like to tackle this over the winter. can't stand the leak any longer. i have tried the search feature as well and got about 16,000 posts, so i may not be using it right. thanks.
