Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: leak down test question
Robert J Hampton
12-23-2012 06:19:47
I pulled the head this morning head gasket was bad inbetween the cylinders where the head bolt goes and heavy exhaust build up on the head bolts. Should I have the head resurfaced when replacing the head gasket?
Phil Tibbetts
12-23-2012 07:59:56
 Re: leak down test question in reply to Robert J Hampton, 12-23-2012 06:19:47
Check the head for flatness and then resurface it only if necessary. I would recommend new head bolts tightened to the proper torque, also coat only the bodies of the new bolts with never seize so the head will come off easier if you ever need to remove in the future.
Robert J Hampton
12-23-2012 08:48:15
 Re: leak down test question in reply to Phil Tibbetts, 12-23-2012 07:59:56
How can I check the head for flatness? The Gasket that was on this engine was a copper one, would that be an orignal gasket? If not I am thinking someone may have replaced the gasket but not the bolts and did not get the correct torqe on them.
Phil Tibbetts
12-23-2012 09:43:08
 Re: leak down test question in reply to Robert J Hampton, 12-23-2012 08:48:15
You never know what has been done when you buy a used tractor. But few people replace the bolts (including me). That being said and without any history on the tractor, and a bad gasket, I would replace the bolts. A good precision strait edge can be used or take it to a shop that has the the means of checking it. I like to clean both surfaces real good and lightly sand both surfaces with emery to give the gasket a good surface to bite into. You might want to re torque the head after a few hours.
This is just my way of doing it. Maybe someone else has a better idea.
Robert J Hampton
12-23-2012 09:58:59
 Re: leak down test question in reply to Phil Tibbetts, 12-23-2012 09:43:08
any idea where to buy new head bolts?
mike paulson
12-23-2012 11:08:47
 Re: leak down test question in reply to Robert J Hampton, 12-23-2012 09:58:59
just go up to the top of this page where it says tractor parts. thats a good bet...
