satchmolips
MF135, early swept axle type.
Sorting out the lights on this. It has rear lights on mudguards (red back, white spot type front of mudguards) and a plough lamp. There is a loom around mudguards with a set of connectors at base of right hand mudguard. But there is no feed to this from anywhere. I guess there would have been at one time but as it has had a clutch or two in it"s life it has been lost. Question is, from where and how should the feed be routed. Probably off the back of the light control switch but where then? Also, would just one live feed to the connecting block do as they would all need to come on at same time? Any help gratefully received
