| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: 1100 Massey clutch?
[Return to Forum]
| Author |
[Modern View]
| 1100 MF question
12-18-2012 11:28:17
66.226.104.81
I have an 1100 MF that has been sitting for awhile (1-2 months).....and when I went to start it it will not shift into gear. Doesn't mattre if in high/low, etc. Can start it in gear, but when apply brakes or clutch it keeps going. Is there an inspection cover or what should I try to free it? Assumed clutch is "stuck"...wondered about putting it in gear while engine is off and trying to rocket it back and forth? Again, when tractor is running and you shift into any gear it just grinds...any thought?? again--it is shedded and has never done this or acted up. |
[Reply] [No Email] | |
| Robert major
12-19-2012 15:52:48
216.81.1.243
Re: 1100 Massey clutch? in reply to 1100 MF question, 12-18-2012 11:28:17
| Hi The 1135 has an inspection cover, it has a greaser in it for the release bearing. a lot of other masseys have plates under the clutch housing, so don't see why not. As the other poster said try it in gear and stand on the Brakes I have done this on a fordson that stuck and it worked for me Just make sure the stop works good, If not ya might need clean shorts L.O.LMaybe the seals are leaking on the motor or transmission input and oil has stuck it too seen different colors do this once in a while. I remember an old guy telling me that blocking the pedal down for a long time is not a fantastic Idea as the springs are under a lot more tension and it weakens them over time. Good luck Regards Robert |
| Dieseltech
12-18-2012 20:39:19
199.16.223.2
| You may have a release lever damaged and not pulling pressure plate away as it should. Drive disc may be rusted/sticking to flywheel. Early tractors had a single clutch, late models had 2 drive discs with a floating plate between the discs, it can hang up on drive tangs also and not slide causing disc drag. Have you tried driving in hi 1st, clutch down and tapping brakes? It may work IF it is just rusty. Dad's 1100 did stick once, but it released ok with the brakes. If tractor has to sit unused may need to start blocking down clutch pedal. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
