Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Bleeding internal hydraulics - MF154
[Return to Forum]
Gerard Morris
12-17-2012 05:50:52
193.201.47.11
Thanks to your help on my earlier post, I think that I now know where to get at the pump and filter for my MF154S (Italian made). As this is underneath the sump I foresee a long and messy job just to have a look inside.
My problem arose when I ran the hydraulic oil level too low and the 3 point lift slowed and then stopped. It has been refilled but still does not work. No bad sounds. Might this just be a case of the hydraulics needing bleeding after they ran low ? Would make sense but I cannot think how to bleed them. Do they usually self prime ?
Your help is much appreciated. I have plenty of mechanical experience with the external bits but limited on the internals and am short on time at present so do not want to open everything up unless I really have to.
[Reply]   [No Email]
Masseynut(Australia)
12-17-2012 09:14:44
123.211.146.110
Re: Bleeding internal hydraulics - MF154 in reply to Gerard Morris, 12-17-2012 05:50:52
The Landini/Massey models were a pain to prime even if the washable strainer was removed for cleaning.
I'd suggest to loosen the four small bolts retaining the pressure pipe on the pump, then start the tractor. Run at idle only. This helps prime the pump with no resistance "downstream". Once oil flows from the outlet of the pump, shut off engine, check that the "o" ring is still seated in it's groove on the pipe, and tighten the bolts. Don't run the tractor for anymore than a minute or two while bleeding, as damage may occur from running the pump "dry".
If it still fails to prime, you can either try removing the breather under the seat, and pressurising the transmission case with air from the workshop compressor, or overfilling the rear end with excess oil, draining off after priming the pump,
let us know the outcome,
Evan.
  [Reply]  [No Email]
Gerard Morris
12-18-2012 06:49:54
193.201.47.11
Re: Bleeding internal hydraulics - MF154 in reply to Masseynut(Australia), 12-17-2012 09:14:44
Thanks Evan - very helpful. That should keep me busy over Christmas !
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
