Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Removing rear wheel hub 1951 Massey Harris 44
[Return to Forum]
MHW
12-16-2012 17:56:02
74.242.204.226
Trying to remove the rear wheel hub on a 1951 Massey Harris 44, and it"s stuck. Removed the cover from the hub on the axle, but cannot get the hub to move.
Have tried banging with hammer, pulling with hydraulic jack and chain, used plenty of PB spray, heated the wheel, nothing works, hub won"t budge.
Any ideas?
[Reply]   [No Email]
MHW
12-18-2012 05:01:57
152.2.204.5
Re: Removing rear wheel hub 1951 Massey Harris 44 in reply to MHW, 12-16-2012 17:56:02
Thanks for all of the helpful tips. Finally got it off after enough banging and heating, and setting up the jack puller to apply pressure in the opposite direction inwards, and it finally broke loose.
  [Reply]  [No Email]
Mike in Mn.
12-17-2012 17:45:57
74.37.53.37
Bob H from Missouri has the right set up, instead of using the jack I have used a spacer piece of shaft and tightened the gr 5 threaded rod tight and then set a bug burtha propane torch on the hub for a half hour or so, when things start smokin keep tightening and hit the end of your home made puller with a mall and it will start to move. I drove one on the farm once for two years with the bolts loose before it started to creek when you backed up,still took all afternoon to get it off. Then what is funny, get it all cleaned up and replace the seal and shim every thing nice and then you can't keep them tight!!
  [Reply]  [No Email]
Bob H from Missouri
12-17-2012 03:40:40
69.140.31.230
I made myself a puller. I used a piece of 3/4" plate, drilled holes same pattern as hub, and all thread with nuts and washers. Insert a 40 ton jack in the cage with bottom of jack against plate and top against axle end. Pulled it so tight it won't jack any more and smack the back end of hub with sledge hammer. Once it pops, spray with PB Blaster and pull it rest of way off. Bet I've pulled 20 of them with it with success on all of them. It even snaps the pins that hold the key in position on the hub.
  [Reply]  [No Email]
mattwillson
12-16-2012 19:03:36
70.54.6.134
try driving around the yard for a few minutes, try not to get too far from the shop though.
  [Reply]  [No Email]
David G
12-16-2012 18:17:32
205.215.206.18
I had to cut one of mine off, they are a bugger. I have heard of others pulling the axles and putting them in a press.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
