My PTO break is not engaging ie wont stop turning unless there is a load on it - spreader with gate closed etc. When you engage the PTO it turns on - no problem with the pump etc...
Its been a long time since I split this tractor because of the pump I believe...What is the procedure?
Drain and drop fuel tanks, drain hydrolic, (am i splitting behind the engine? - drain oil). Jack cab at rear, disconnect any wires, hoses... I recall some issues with disconecting and reconnecting the shifter linkage -advice?
Which end should I block in place the rear or front - to roll the other end apart?
Any other advice? Anything else I should be looking to fix while I'm in there.
I'm tired of always having the tiller , brushcutter or whatever turning. This tractor has been through a lot, but it still ears its keep...just want to make it safeer.
