Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: MF 35 Perkins Air Filter Option
Masseynut(Australia)
12-14-2012 01:50:11
Is there a reason for replacing the oil bath assembly? These have been proven to be a more efficient unit than the "dry" element assemblies. Oil bath assemblies can literally work without servicing until your engine "starves" for air, without dusting the engine. Try doing that with the later type. If your service procedure leaves a little to be desired, you won't get away with that using the paper assemblies, for what it's worth, Evan.
mem
12-14-2012 05:47:36
 Re: MF 35 Perkins Air Filter Option in reply to Masseynut(Australia), 12-14-2012 01:50:11
Masseynut, thanks for your thoughts. I had read elsewhere that the oil filters are not as effective as paper. In addition it currently has an unsual air filter system, it is not the original air filter cannister. It is a horizontal cannister that extends out the right side of the hood(bonnet) and has a paper filter. There are no part numbers on the current air filter and I have not been able to determine where I can get a replacement filter. Also, I would prefer to replace the current air filter with one that is the original position. Maybe my best option is to buy a new stock unit. Thanks for your advice.
Dean
12-14-2012 10:11:31
 Re: MF 35 Perkins Air Filter Option in reply to mem, 12-14-2012 05:47:36
The oil bath filter is far superior to the paper element type. The industry changed due to costs.
It sounds like your 35 has already been changed over to the 135 type. I once had a 61 Perkins 35 with a 135 filter.
Failure to service the oil bath filter regularly allows water to condense in the oil cup which will eventually cause corrosion pin holes. Not uncommon.
Dean
Copyright © 1997-2015 Yesterday's Tractor Co.
