Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: MF152 Hydraulic Filter Location
[Show Entire Topic]  [Return to Forum]
DavidP, South Wales
12-13-2012 09:58:07
78.148.188.236
Hi Gerard,
There are three versions of the hydraulic pump fitted. The filter is in essentially the same place at the rear of the pump but access is different.
If your tractor is a later one look first on the underside of the rear centr housing, roughly on a line from the transmission dipstick but on the underside.
You may see a triangular plate held to the casing by three nuts or bolts. Drain the transmission and remove the plate. Inside you will find a spring clip and then a nut. Remove both and the filter will drop out.
If you don't have the plat access can be gained through the left hand side-cover. This however will depend on what equipment is fitted such as IPTO or auxillary pipework,
Assuming you don't have eithe and you have removed the cover you should find that the top of the filter is wired to the backplate of the pump. Cut the wire and use a small pair of pliers to undo the butterfly on top. Try and lift the complete assembly out as one. You will have the top cup, filter and bottom cup. There is a thin section O ring which normally stays on the pump. Ensure that it is not lost. Clean or renew the filter. If you don't have proper locking wire use a domestic electricalwire strand (cooker cable). Twist the wire ends after threading through the butterfly and backplate. Be careful as there are many potentially sharp edges on components around the filter.
Replace the cover and refill with oil.
If you have IPTO or aux pipework it may be necessary to remove the cover.
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
