Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Anti-freeze in oil
Bob Huntress
12-09-2012 22:38:51
Even if you are able to correct the crack, the engine sounds like it will need rebuilding. I would remove the head, clean both the head and block mating surface as clean as you can get them. I use a Scotchbrit pad and a a high speed rotory tool to get all debris off the surface. Then I use a three part dye penetrant spray to find the crack. Depending on the crack, it may be repairable. If so, I'ld probably repair it and rebuild the engine, but it's up to you. From the sounds of it though, you will have to do an engine overhaul. Are you fairly proficient welding? You may be able to weld it with nickle rod. Of Course you'll have to file it down real steady afterward.
