Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Anti-freeze in oil
[Return to Forum]
Notsofastfreddie
12-09-2012 09:33:36
174.29.253.207
I have a 1959 mf 65 gas tractor with anti-freeze in the oil pan. Just got the tractor, with no history on it. Compression chk on cylinders is 150 for the front 3, 135 for back one, leaked down 30 lbs in 10 minutes. Is there a way to isolate the leak prior to tearing engine apart? If the block is cracked, is it repairable? The engine did start and run ok, just lots of bearing noise. Thank you for any help you can offer, Fred
[Reply]   [No Email]
Notsofastfreddie
12-10-2012 07:38:38
174.29.253.207
 Re: Anti-freeze in oil in reply to Notsofastfreddie, 12-09-2012 09:33:36
Thanks to everyone for their comments and help. I have hardly any money into this tractor so far. Good tires, sheetmetal and loader, so worth putting a little effort into. Not to mention a good excuse for my 17 year old and I to work together. Tried some sealant from NAPA, and it stopped the leak while running. Ran into the pan while parked for several months. We will pull the head and see what's there. Thank you again and MERRY CHRISTMAS. Fred
[Reply]  [No Email]
Eric in IL
12-10-2012 13:52:20
208.124.66.242
 Re: Anti-freeze in oil in reply to Notsofastfreddie, 12-10-2012 07:38:38
It's time to inspect the bushings at the pivot point on your front end if it is a wide front. The big bushing only has a wall thickness of about a sixteenth of an inch. A loader can make that bushing look sad in a hurry.
I agree with all said by Aaron Ford.
[Reply]  [No Email]
Our Farmer
12-10-2012 06:43:09
75.243.134.50
Pretty sure that's a dry sleeve block. From the leakdown, I'd go on the assumption it's a head gasket, and hope the head's not cracked.
Gotta pull it.
[Reply]  [No Email]
Aaron Ford
12-10-2012 12:54:23
76.92.68.163
 Re: Anti-freeze in oil in reply to Our Farmer, 12-10-2012 06:43:09
Continental G176 is a wet sleeve block. O rings are used to seal the sleeves. The block can crack between the cylinders but mine wasn't. It sounds like you have a cracked sleeve. The sleeves come with the rebuild kit. Aaron
[Reply]  [No Email]
Bob Huntress
12-09-2012 22:38:51
98.66.35.159
Even if you are able to correct the crack, the engine sounds like it will need rebuilding. I would remove the head, clean both the head and block mating surface as clean as you can get them. I use a Scotchbrit pad and a a high speed rotory tool to get all debris off the surface. Then I use a three part dye penetrant spray to find the crack. Depending on the crack, it may be repairable. If so, I'ld probably repair it and rebuild the engine, but it's up to you. From the sounds of it though, you will have to do an engine overhaul. Are you fairly proficient welding? You may be able to weld it with nickle rod. Of Course you'll have to file it down real steady afterward.
[Reply]  [No Email]
mattwillson
12-09-2012 16:56:16
70.54.4.100
I have had really good luck with irontite. My das 270 leyland responded well to a treatment a year ago. It had leaky liner seals.
[Reply]  [No Email]
rustred
12-09-2012 11:47:26
70.28.245.77
if you have a tractor with antifreeze in oil and lots of brg. noises, engine is not ok and that is a complete engine tear down job and is worth more than the tractor.
[Reply]  [No Email]
mike paulson
12-10-2012 02:58:46
24.213.183.46
 Re: Anti-freeze in oil in reply to rustred, 12-09-2012 11:47:26
tell me your not serious???
[Reply]  [No Email]
rustred
12-10-2012 08:11:49
70.28.245.77
 Re: Anti-freeze in oil in reply to mike paulson, 12-10-2012 02:58:46
i certainly am serious. i am looking at worst case senario , he says antifreeze in oil and brg noises... you run away from those deals not buy them. from bare block to back to running is nothing to spend 5-6000.00 on an engine. if the head is cracked thats at least 1000.00 or more for head work.engine rebuilding is not cheap, as lots of it is specialized work. unless your a machinest and mechanic and can tackle the work yourself.
[Reply]  [No Email]
old
12-09-2012 09:44:39
209.86.226.27
Not sure if it is a wet sleeve engine or not but if it is one thing to do is pull the oil pan and see if you can see coolant leaking at the sleeve seals. You can also do that to see if it is coming from around one of the piston as in a head gasket leak
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
