Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: MF 230 diesel won't start
[Show Entire Topic]  [Return to Forum]
samn40
12-07-2012 17:17:24
217.43.214.161
First identify which pipe leads from the secondary fuel filter to the injection pump....remove it at the pump end and hand prime the tractor at the fuel lift pump on the opposite side of the tractor. If the fuel does not flow the full of this pipe then you have issues with dirt in either the tank strainer, or the filters...or you may have a problem with the lift pump (valves sticking) Providing you have a full flow , reconnect the pipe. The next issue is bleeding the injector pump, loosen both bleed screws and hand prime . Next loosen one fuel pipe, loosening it at the pump is sufficient, now crank the engine...you should be getting a good 'squirt' of fuel each time the pump injects on that pipe...If not the rack inside your injector pump may be stuck, usually a few sharp blows with a block of wood on the side of the pump will release this. Once you get fuel 'squirting' keep on cranking at about half throttle with the pipe still loose until it fires up, then retighten the pipe with the engine still running,
WARNING...Diesel fuel can be harmful to your skin, wear adequate protection and keep away from direct sprays of fuel.
That is about the best I can do from my side of the Atlantic....Sam
[Reply]   [No Email]
Pat D.
12-07-2012 17:50:42
75.230.193.176
Thanks Sam, I'm on it.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
