Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: MF 230 diesel won't start
[Show Entire Topic]  [Return to Forum]
Jerry/MT
12-07-2012 15:00:44
206.183.116.145
As long as you have compression and fuel to the cylinders and your battery is trog enough to tuern the engine over it should dtart. Assuming your battery is capable of turning the engine over and you have adequate compression(no stuck valves, etc) I"d say your problem is fuel supply. Make sure that you have adequate fuel flow from the tank to the filteri inlet. Crap and corruption can clog the tank strainer and associated lines to the filter. Make sure the fuel lines are tight so thsy can"t suck air. Bleed the sytem starting at the filter , through the pump, and finally at the injectors. Just crack the fuel nut at the injector open one at a time or all at once when you get all fuel to the injectors than tighten them up and try a start.
i have some general instructions for bleeding a diesel if you need them, let me know.
[Reply]   [No Email]
Pat D.
12-07-2012 16:09:53
75.230.193.176
Re: MF 230 diesel won't start in reply to Jerry/MT, 12-07-2012 15:00:44
Jerry,
Thanks for the help. Your instructions would be most helpful. I have enough in the way of shop manuals for this tractor that I can probably follow the steps.
Pat
  [Reply]  [No Email]
Jerry/MT
12-08-2012 19:55:44
206.183.116.145
Re: MF 230 diesel won't start in reply to Pat D., 12-07-2012 16:09:53
Here you are Pat.
Bleeding a Diesel Fuel System
Start at the fuel outlet of the tank (inlet to the filter). Shut the tank valve, remove the line at the filter inlet and holding a suitable container to catch the diesel fuel, open the valve. You should have a CONTINUOUS rush/flow of fuel out of the line. If it dribbles or is intermittent, check the fuel cap for a blockage of the fuel vent or the strainer upstream of the valve for clogging. The strainer/screen is attached to the shut-off valve, and is positioned up inside the tank. You will have to drain the tank and pull the valve to clean the screen.
If you have good fuel flow at that point, reconnect the line and open the bleeder screw at the top of the filter. Turn on the tank valve and wait till you have a steady flow of fuel with no bubbles at the top of the filter, then close the bleeder screw.
Your pump may have a bleeder screw. If so, open that until fuel streams out with no bubbles, then close it. If you cannot identify the bleeder screw, loosen the inlet connection at the pump and purge air at that point.
Go back and make sure ALL the fittings in the fuel delivery system are tight so they cannot suck air.
Make sure the battery is fully charged. Loosen the fuel fittings at the injectors, either one at a time or all at once. Crank the engine till you see all fuel at the injector fittings and then tighten the fittings. If you do indvidual fittings, the engine will usually start before you get to the last fitting.
Alternatively, you can "tow-start" it to save wear and tear on your starter. Leave the injector lines cracked open at the injectors at first to purge the lines. Then tighten them up and she should start.
Your injection pump puts out a very small amount of fuel (high pressure/low volume). BE PATIENT. If the lines are totally empty, it takes a lot of cranking to fill them up.
sixbales & Jerry/MT
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
