Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
12-02-2012 11:59:25
go to the top of the site page in the search for box type in alternator wiring,that will give you a list of previous post, one of them should have a diagram if not go to the IH page i know for sure they have been on there
William Beale
12-02-2012 12:52:41
 Re: AMP METER in reply to gbs, 12-02-2012 11:59:25
Thank you so much for the infomation.
Duner Wi
12-02-2012 18:06:48
 Re: AMP METER in reply to William Beale, 12-02-2012 12:52:41
I just installed an alternator and wired mine like yours except for ammeter. White excite wire to Acc term on 4 position Sw. Red sense wire back to battery term on Sw or in my case battery side solenoid. Should amount to same thing in the end. Large red wire on Alt + to battery or in my case to the lug where the battery + cable runs to. Same thing in the end. You have an ammeter is the only difference, Sure your battery is not fully charged? Check you voltage across batt terms with engine running and not running. If it is not charging volts will be the same. If it is charging you should see at least 13 volts or more. You will find most all wiring diaphragms with sense wire hooked up wrong according to what GM did. You want to read the volts back at where the load is taken from. Good luck.
