Need advice to start a diesel MF175..The tractor was running well..I stopped it to remove the cab and it will not restart..the engine turns over but it will not start...I removed the stop level cable but I have made sure that the stop lever on the pump is completely ccw and the throttle was held in half position(suggestion from DavidP). I am assuming that my problem is fuel related. I slightly loosen the compression bolts on top of the injectors and turned over the engine, fuel leaked out but not with any pressure as the engine was turning over. Can I loosen these bolts completely... Also I replaced the primary fuel filter(it had not been replaced in ages)..Do I need to bleed the fuel system now...What else should I look at to resolve this frustrating problem..Thks..Ray
