Maurice Hood
New User
I need help with a fuel leak on an AD3-152 engine in a MF-135. I have a leak at the top of the injector pump where the leaver is connected that shuts off the engine. Is it just a matter of taking the nut off that holds the arm on that connects to the leaver rod and replacing some type of seal or gasket or is it much more complicated? I’m no mechanic but have tinkered on gas engines in years past but know absolutely nothing about diesel engines. I have heard that if I get air in the fuel lines I have a problem so I’ve been careful to never run it out of fuel so haven’t had that experience yet. However I was hoping that this leak was something I could fix myself. Any advice would be greatly appreciated and a diagram would be very helpful as I have not yet found one on line. Thanks,
