What engine?
dgerth
I have TO 20/30, not sure which but it has a Z129 motor with a "cocktail" in the pan, quite a mixture.
What motor, preferably larger will fit without too much engineering. It has the hi/lo shift lever on the lft side of the transmission too.
dg
the z129 would make it the TO30 as far as the cocktail i don't know. the TO20/30 are so close to being the same motor but if you know what to look for there some pretty big differences. if you need more info you should ask on the Ferguson forum that is the tractor you have and there's much more help for that model there.
