Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: mf 65 pto
[Return to Forum]
Jerru W
11-28-2012 19:28:45
198.228.228.145
Last year put both the new clutch plates in and adjusted according to the book. Also put a new rear seal in. However, no matter what I adjust can not get the pto to run any equipment as it slips. The ground drive works not sure if this makes any difference. Wondering if you have any ideas to help resolve this problem. I am thinking maybe it is the Bellville spring or the pressure plate next to it.
[Reply]   [No Email]
Masseynut(Australia)
11-28-2012 21:30:11
124.186.112.65
 Re: mf 65 pto in reply to Jerru W, 11-28-2012 19:28:45
You have mentioned the problem part(s) in your question. Either the PTO pressure plate and/or the "false" flywheel are probably dished because of heat distortion.
If you remove and disassemble the clutch, rest a straight edge across both plates, and see if the faces are perfectly flat. Chances are that you will see "daylight" towards the inner edge of both plates. This result means that you will only have the drive plate sandwiched on the outer edge of the plate when in the engaged position.
DO NOT try to re-claim the plates by machining, as this will decrease the clamping tension on the drive plate, and upset the ability to adjust the clutch as well.
If these plates show signs of having been hot at some stage, I would also replace the belleville spring at the same time. Heat has probably weakened it as well.
hope this helps,
Evan.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
