TractorLinks.com
Show Parts for Model:
MF 1085 three point lift problem
lemroy
11-28-2012 18:58:47
I have had both hyd pumps replaced on my MF 1085 but when I put a load on the three point, it won't lift. It will lift without any load on it. Could this be an internal leak or out of adjustment. Thanks Roy
BigMarv1085
12-01-2012 18:49:37
 Re: MF 1085 three point lift problem in reply to lemroy, 11-28-2012 18:58:47
I had the linkage come loose on mine once and had that same problem. There are the 2 flat bars bolted together and I disconnected them and pulled the linkages by hand and found that I had to shorten the linkage.
lemroy
12-01-2012 19:24:44
 Re: MF 1085 three point lift problem in reply to BigMarv1085, 12-01-2012 18:49:37
Thanks for your response. Where on the tractor do I find the linkage you refer to? How do I fix it?
BigMarv1085
12-03-2012 17:18:22
 Re: MF 1085 three point lift problem in reply to lemroy, 12-01-2012 19:24:44
the linkages are on the rt side up under the 3 pt arms, I will take a look tomorrow and give a better description
RussUPpswrd
11-29-2012 13:22:38
There should be a hydraulic test port where you can install a pressure gauge and see if the full spec hydraulic pressure is still achieved. If not you may have to rebuild the hydraulic pump or swap with a better pump. Should also consult a tractor hydraulics shop for ideas or a repair job.
