Char-Lynn PTO Hydraulics
Hi Harry, Eaton Corp took over Char-Lynn yrs ago.
Try 877-358-4376 or 300-728-4376 for location by
you or google Char-Lynn hydraulic motor. Chuck
What kind of parts do you need? I rebuilt a engine driven Char-lynn pump of the same era and all parts I needed to do it could be had from McMastercarr.com
Donovan from Wisconsin
When I took mine apart, I got a new front seal from NAPA, and I'm fabricating a new PTO shaft coupler using parts from Tractor Supply.
All I did was open mine up because the spools were stuck. Ruined the front seal in the process.
