!68 Massey Hydraulics
Just trying to figure out the adjustment for my Hydraulics .Presure is ok .Front end loader works fine also.But when i lift on the 3point linkage no lifting power .They do raise but ica push them back down
The front loader may be working off the auxillary pump, separate to your rear linkage pump. Do the hoses come off the PTO shift side-cover for the loader?
You say that the pressure is Ok, where is the pressure Ok?
If the rear linkage is doughy, it may be a fault with the lift linkage pump, lift cylinder, etc.
Let us know where that loader is plumbed from,
Evan.
