TractorLinks.com
Show Parts for Model:
Re: trying to start old MF35
Inno
11-22-2012 12:20:10
Well if all those things check out then it runs!
Clearly that is not the case so at least one of those things is the culprit.
I'm not trying to be a smart a$$ but when all of those things seem to be ok, I start checking things over again, trying different possibilities.
From what you described in your original post you have already done all of the things all of us might do when troubleshooting an engine. I don't think anyone is only reading part of your post, I think when the obvious things don't work then we suggest things that have helped us or others in the past.
This post was edited by Inno at 12:24:06 11/22/12.
robreynolds
11-22-2012 14:52:21
 Re: trying to start old MF35 in reply to Inno, 11-22-2012 12:20:10
You're probably right. It probably does run. Come to think of it, it would probably run (poorly) even if I had the wires going clockwise, because 2 of them would be correct, and it would probably at least fire even if there were up to 3 stuck valves or if the distributor were rotated several degrees.
I suppose I just had to go through it step by step and think about it, and now that I have, I recall that right from the beginning the starter got kicked out from time to time when I was cranking the engine. That's the direction I'll go in next, but it will have to wait until Sunday when my family comes home. Until then I'm not going to fool with it any more.
