Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Draft-Position control problem TO35
john in the highlands
11-22-2012 09:36:29
I've worked on a mf35. There's a lot of nooks and cranies for water/sludge to catch in and not drain out. if you don't take the pump out etc, you be best to flush-out a few time. I had lots of scoring on the pump's pistons and the lift cylinder ending up replacing a lot.
When you change the fluid take the dip stick cover plate off and look in, you should be able to see both of the control levers in action, each has an adjusting nut. Don't be sticking your hand in while it's running, you can see alot of the levers responsiveness without the engine running.
