TractorLinks.com
Show Parts for Model:
Re: mf-35
2tractors
11-20-2012 05:35:57
First thing I look at is the dash tags last letter for and M and the pto shifter for ground position which indicates 2 stage.Check dipsticks on engine and tranny for water, loose front end means lots of use, if it runs check oil pressure and clutch,look for a leak from the weep hole and expect a slight drip.
brian stanek
11-20-2012 12:03:49
 Re: mf-35 in reply to 2tractors, 11-20-2012 05:35:57
no they are a package deal. one is serial no-SNW-236188 other is SGM172751 didnt get third serial but now armed with more good info will take a second look. thanks for the info.
chas
11-20-2012 13:44:28
 Re: mf-35 in reply to brian stanek, 11-20-2012 12:03:49
On my info ....
SNW 236188 = ‘Should be’ =Perkins (3cyl) diesel, with Multipower, One of the most reliable engines of the era. Multipower, good if it works, can be problematical. Built 1963. SGM 172751= ‘Should be’ = 4 cyl Gas TO35 with dual clutch, built 1957 - but see also what Dan said.
