Massey Harris Pacer Clutch Shaft
ff1221
New User
My dad is working on a Massey Harris Pacer for a guy and the clutch shaft has been stripped, he is looking for instructions or a parts breakdown to tell him how to remove the shaft, anybody have this info
TheIT manual says to split the tractor-disconnect
brake rods at pedal shaft and remove the two carriage bolts which attach frame side angles to
the frame cross angle. Remove the four trans-to torque tube bolts and seperate tractor. Then a
couple illustrations. The splined coupling which is welded to rear of clutch shaft is fastened to
trans input shaft by cotter pin which must be re-
moved. Then tells how to re'assemble. This should
cover, tho abbreviated. I have a lightly used IT
for $6 if you would like. Chuck
