Completly different animal, different eng, trans , heavier. Closer to a 44 , with the major difference beeing the larger engine.
33 had OHV 201ci engine, 30 had 162ci Flathead.
33 has one more bar in the grille and a larger fuel tank.
Same belly castings, trans casting, axles etc...
Valve cover might be tight to bottom of hood, but engine will fit frame. they have the same front tub, just different bellhousings and front mounts. Have seen a 55 engine in a 33 so anything is possible...
