Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: MF 230 diesel---got it started today
11-14-2012 15:33:38
The shaft repair is simple if you take your time! Clean everything real well all around and above the pump and remove the linkages. Now remove the two nuts on the top between the throttle shaft and the strangler shaft, these will probably be wired together., also remove the copper washers. and the levers from the both shafts. Carefully lift the lid off the pump, BUT....tip it up slightly first and look in and remember what position the springs are in. unhook everything and push out the shafts and replace the 'O' rings. rebuild it in reverse order, but remember to fit the springs and linkage in the correct positions. Do not overtighten the nuts on top as it is easy to wring the studs!! Take loads of photos and even try to get one inside the pump when you tip it up slightly. Good luck....Sam
