Anonymous-0
Would like to obtain a maintenance manual.
Need to know how/where to check the rear axle
gear oil ... and what weight is used. Had some
small leakage that has since stopped with use.
Also if there are any other oil(transmission?)
fluids to check. I know about the - engine, air filter, and hydraulics (whats recommended for
hydraulics?)
Also I had wanted at one time to be able to use
a post hole digger with this tractor, but was
told its not possible due to the position of the
pto. Any thoughts?
hydraulics?)
pto. Any thoughts?
