MF 50 power steering control valve broke, cant find parts?
Anonymous-0
The control valve pours out fluid, dealer says parts such as orings etc..... Are obsolete, can't find one anywhere, it is the valve the hoses go into, sits on top of cylinder, restored tractor now can't move cause fluid goes everywhere, anybody have any ideas where to get parts
Maybe used parts try Wengers Of Myerstown go to there web page if you don't see it call them they might know were
Cody, Look at this post, that is if I pasted it in OK. Really no parts to find other than o-rings, linkage pins and a SKF 6741 seal.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=mf&th=126592
Most dealers don't care about the old stuff and are most often useless unless you are really lucky and find a good one. You will have to find the parts yourself by taking the valve apart, looking at the parts books which sometimes have o-ring dimensions listed, and locating the seals/o-rings needed from various sources.
Dan
(quoted from post at 19:48:04 11/13/12) The control valve pours out fluid, dealer says parts such as orings etc..... Are obsolete, can't find one anywhere, it is the valve the hoses go into, sits on top of cylinder, restored tractor now can't move cause fluid goes everywhere, anybody have any ideas where to get parts
Give these folks a call.
They have a seal kit for the MF 50.
A good source for O rings, seals & seal kits.
www.baumhydraulics.com
afarmer
