TractorLinks.com
Show Parts for Model:
Re: Question on auxiliary hydraulics.
Masseynut(Australia)
11-07-2012 22:50:52
Why don't you remove the rear cover from the pump, and slide the gear set out. Also remove the thrust plate but leave the outer "o" ring in place. Refit the cover and now you have a single element (Hi-output) pump.
Jason S.
11-08-2012 06:12:50
 Re: Question on auxiliary hydraulics. in reply to Masseynut(Australia), 11-07-2012 22:50:52
Thats kind of where I was confused.I didnt know if you removed the gears if it would still send oil to that part of the pump, which I guess worse case scenario it would just go on thru and back out in to the housing...I have looked and looked at Agcopartsbook.com at the exploded views and for an 8 speed with no multi power or IPTO they show that dual section pump.I didnt know if originally it was blocked off or just flowed thru or what they done.
11-08-2012 12:34:01
 Re: Question on auxiliary hydraulics. in reply to Jason S., 11-08-2012 06:12:50
From looking at an old pump I have here, I would expect the area inside the pump where these gears originally were, would just become part of the oil pickup on the suction side of the "hi-flow" pump. I would blank off the outlet port on the low flow side as well, and keep the rear "o" ring in place, so the suction side remains "sealed", ensuring that there is no possibility of it "pulling" air. Hope this helps, Evan.
