Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: MF 165 generator and tach drive assembly
[Return to Forum]
JWL
11-07-2012 07:40:54
69.157.9.37
I am trying to put a tachometer on my Minneapolis Moline GVI diesel and I have someone who has proposed I use a generator off of a MF 165 which does appear to be the same (i.e. same size, mounts the same, etc.). The Generator # is 1900341M91 and the tach drive they have proposed fits this generator and is 14 tooth drive and 43 tooth driven and apparently fits Massey 165 Tractors both the gas and diesel versions. They have also proposed I use a tachometer off of the MF 165. All this I believe will work fine but the one concern I have is the ratios of this drive. My tractor has a 2:1 ratio between the crankshaft and generator pulleys so I need either the generator drive or the tachometer to convert this ratio back so that I am reading the actual crankshaft speed. It appears that based on the gears in the tach drive that it is a 3:1 ratio instead of 2:1.
Are there other tach drive options that would work for my situation (i.e. 2:1)?
What are the pulley ratios on a MF 165?
Does the tachometer have a ratio built into it or is it just 1:1?
Any help/information would be appreciated. Thanks in advance for your help.
[Reply]   [No Email]
Dieseltech
11-07-2012 08:23:46
75.146.127.110
 Re: MF 165 generator and tach drive assembly in reply to JWL, 11-07-2012 07:40:54
Not sure but I think all had same gear set with no ratio choices, speed change was done with drive pulley. I use a light/tape to read crank speed then change pulley size to adjust tach speed reading up or down as needed.
[Reply]  [No Email]
Dieseltech
11-07-2012 08:11:06
75.146.127.110
MF 35, 50, 65, and 85 gas tractors had generators with tach drives too. If you need change the drive pulley to get the correct tach reading. Also if alternator is desired with a tach drive these were on late MF 175 and 180 diesels, also on AC 190 XT and AC 200 models. Hope this helps.
[Reply]  [No Email]
JWL
11-07-2012 08:18:10
69.157.9.37
 Re: MF 165 generator and tach drive assembly in reply to Dieseltech, 11-07-2012 08:11:06
Thanks for your response. Do you know if the tachs on these tractors had a ration conversation to them or was that done in the tach drive?
Also, what was the crankshaft pulley size relative to the generator drive pulley?
Thanks again for your assistance.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
