Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: massey 245 starting problems
mike sirls
11-05-2012 16:58:37
i tried a new solenoid still nothing. decided to check the ignition switch when i unpluged it one of the prongs broke off. it was kind of corroded. would the switch not working have anything to do with the gauges not working?
11-06-2012 13:14:45
 Re: massey 245 starting problems in reply to mike sirls, 11-05-2012 16:58:37
Gearhead hit it, there is a wire from the big terminal on the solenoid that carries power to the instument cluster. Trace that wire end to end and insure that is making good contact. Also, while not directly tied to your problem, check the two fuses on the dash. BTW, when it started after you shorted the solenoid out that was an indication that your solenoid was OK. Replace the ignition switch and clean the connections, double check the battery connections at BOTH ends and you "should" be good. Otherwise you'll need a wiring diagram and start chasing wires. Good Luck!
