| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: mid 80's MF 2625 - MFWD - front axle not working
[Return to Forum]
| Author |
[Modern View]
| williamar
11-05-2012 09:41:37
67.52.234.226
I am gonna have a look at an absolute auction where there is a MF 2625 for sale. Front Axle listed as not working. Though I am going to assume the tractor runs and drives other than that. I don't care about it being perfect, just need 100 HP. Does running a tractor with a non engaging front wheel axle pose any concern? I mean, I don't know which part of it is broken, the drive shaft, or the axle differential itself. Basically it is reduced to operating as a two wheel drive. Which works for me. Any thoughts on if this is an acceptable approach? |
[Reply] [No Email] | |
| Harry in Ky
11-05-2012 15:53:30
76.177.106.12
Re: mid 80's MF 2625 - MFWD - front axle not working in reply to williamar, 11-05-2012 09:41:37
| Not familiar with this model. Parts book shows it was made in India for US and Canada market. Looks like the drive for front axle is attached to the side of the trans, with most everything involving the shifting/engaging componants outside the trans. That's a good thing, since it seems likely that only one gear would be a real chore to access, and that's probably not the failure anyway. You can operate in two wheel drive. Once you determine what and where the failure is, you can decide what to do next. If the problem is in the side box/shift mechanism, you can either leave it disengaged, or remove the damaged parts and reinstall the side box with those parts missing. If the problem is in the front axle, you can remove the covers from the front outer planetaries, remove the sun gears from the stub axle shafts, and reinstall the covers. The wheels will still turn, but the gears and shafts within the front axle housing will not. |
| williamar
11-06-2012 07:24:01
67.52.234.226
Re: mid 80's MF 2625 - MFWD - front axle not working in reply to Harry in Ky, 11-05-2012 15:53:30
| Very informative response, thank you sir. I like the observation that most of the shifting component is an external box, not inside the housing. |
| DavidP, South Wales
11-06-2012 03:13:56
78.148.51.115
| | Hi, I'd agree with Harry. The essential thing is to determine where the problem is first. Start off by disconnecting the drive shaft at the rear end. Make sure that you have the 4WD engaged, Support the driveshaft and move the tractor. If the drive flange turns you will have drive to the shaft. If it does not the problem is in the middle region of the tractor. Try it again with the 4WD disconnected. If the flange does not turn all appears to be OK in the middle region of the tractor. Make sure that there is no movement from oil drag. Turn the driveshaft by hand. If you can turn it the problem is at the front end. Jack each side up seperately and spin the wheel. Listen for any strange noises. I'm guessing that it would be a crownwheel and pinion problem. It is essential that you inspect it and make sure that nothing is broken/can break and possibly punch a hole in the casing if it gets caught up. DavidP, South Wales |
| williamar
11-06-2012 07:25:11
67.52.234.226
Re: mid 80's MF 2625 - MFWD - front axle not working in reply to DavidP, South Wales, 11-06-2012 03:13:56
| Thank you sir for the detailed trouble shooting reply. That indeed sounds like a winning approach to isolating where the problem is occuring. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
