TractorLinks.com
Show Parts for Model:
Re: fuel leak T030
2tractors
11-05-2012 05:28:30
My brother had that with his to20 after leaving shutoff valve on. The float needle gets trash in it allowing the gas to flow into the manifold, cylinders,air breather, and oil pan.Change oil and clean out the breather. Always cut off the gas no matter how long you plan to leave it idle. I also disconnect the battery.
Blanx
11-05-2012 06:22:16
 Re: fuel leak T030 in reply to 2tractors, 11-05-2012 05:28:30
i shut the fuel cutoff to off when i used it last, i wonder if the trash has it stuck open
2tractors
11-05-2012 16:37:38
 Re: fuel leak T030 in reply to Blanx, 11-05-2012 06:22:16
Take the output hose/fitting off and turn off the gas and see if it's leaking.If your not stuck on original equipment then a ball valve from any hardware store and a see thru filter will solve the leaking.
